MPC4503 Usb slot not recognize
  • Greyfox1223
    • 8
    Hi Guys,
    Good Day!
    I have 3units of MPC4503 that cannot recognized USB slot. I already checked the connection from the IPU, connect and disconnect but still no luck.
    I also tried to go to SP mode "SCANNER" to disable the USB option and enable it again. DO I need to replace the IPU and USB Cable?
    PLease share your ideas....thanks in advance
  • davel
    • Oct 2011
    • 1103
    Re: MPC4503 Usb slot not recognize
    Make sure your usb us not too big.
    • Greyfox1223
      • 8
      I am only using 16gb usb and before it was working fine.....it just stop working and i dont know why?
      • Garysg
        • Apr 2014
        • 5
        I had a sharp 503 do this I had to reload firmware and it worked just fine
        Originally posted by Greyfox1223
        Hi Guys,
        Good Day!
        • Greyfox1223
          • 8
          I will try and let you know the result tommorow.....thanks man
          Cheers,
          • Garysg
            • Apr 2014
            • 5
            Cheers,
            Also try Google I seen a lot of answers on there for that
            • keithxxiii
              Just a tech
              • Nov 2014
              • 468
              check if it is disabled from the user tools. media slot ->prohibit
              Aye! Cut the crap
              • Greyfox1223
                • 8
                Hi Garysg,
                This morning i tried to update the firmware but still no luck....
                I also tried to use the SD card slot beside the USB slot and its working fine i can print using SD card
                but i cant print using USB stick.
                Thanks.
                • Greyfox1223
                  • 8
                  Hi Keithxxiii,
                  I checked the media slot - >it was selected as "allowed"
                  SD card slot is working fine only USB slot can't detect
                  I have checked also from SP mode "scanner" and "printer" > it was enable
