pdf slow printing - ricoh mpc3002
  • Mark Bbb
    • Jun 2012
    • 1662
    Hello,
    It takes about 4 minutes to print 3x A3 pages, singel sided, color, PDF format.
    From another bundel it took 2 ours for 20 A4 pages, color!
    This problem also occured at the very begin, when the printer was installed, then i fixed it with something i can't remeber (yes, really)...
    They replaced the server and the problem is back...
    Can anybody give us any hints?
    Thanks!
    Greetings,
    Mark
  • Elmo
    • Feb 2010
    • 541
    Re: pdf slow printing - ricoh mpc3002
    Try using Foxit pdf reader had the similar problems printing from adobe to mpc2550 changed to foxit problem fixed
    I Used To Live To Fix Things Now i Fix Things To Live
    • zed255
      How'd ya manage that?
      • 1024
      Make sure of two things:
      1) It is set up to use a 'Standard TCP/IP Port' - I'm seeing newer systems detect printers automagically and installing them using WSD ports which don't work worth a crap and
      2) It is set up with the driver downloaded from Ricoh, not the crap 'Ricoh Class' driver coming with newer systems as it's a piece of crap too.
      Also, I have now seen in multiple cases where the machine communicates really slow because the NIC's gigabit capability is off by default and I feel the 100MB speed doesn't
      negotiate / play well with some switches.
      • Polarbear
        • Feb 2012
        • 1070
        I'm with ZED255 on this "class" drivers.... not worth sh!t.
        It is also worth checking different documents as some PDF docs are not "flattened" properly when they are saved and that causes all kinds of trouble when trying to print something that looks fine on the screen.
        I also agree that Acrobat is not always the most stable reader to use. I have had Reader throw a fit and close with some files....
        Press the GREEN button!!
          • 37507
          Every time I have had customers with slow printing, especially PDF printing, either the driver was the Microsoft "Ricoh Class" driver or the port being used was a WSD port and not a TCP/IP port. Both are the result of letting Windows automaticly detect and install a new printer.
          • JrTech
            • Jun 2013
            • 217
            Morning all. I would re-install the latest PS drivers and firmware (both must be machine specific and not the "class" drivers from Ricoh on your laptop and direct connect to the machine. Print same files and see what happens. If it does the same then you have a machine issue and thats where the Firmware comes in. Check Firmware release as to what it is going to "fix" and see if your issue(s) are in there. Just recently installed a fuser on a an MPC4501 and client complained that BW was fine but Color PDF took about 3 mins per page. Turned off the machine and disconnected ethernet, power plug. This will give the machine a few minutes to clear everything out of temp memory and refresh itself. Also turns out they upgraded all computers in the latter part of 2015 and have been having slight but noticable issues with connectivity.
            Keep in mind that as companies upgrade to the lastest in security and other enhancements on the networks and "forget" about the printers, MFPS, Scanners. Doesnt seem like a big issue now, but they build up after a while. I have made it a point to keep up on the firmware and try not to let it get more than 2 versions ahead.
            Hope this helps.
            • eescamilla
              • Aug 2015
              • 58
              If they are using Adobe, on the print screen menu there's a button "Advanced", in there check mark the box next to "Print as Image". This has always helped in the past with pdf issues. This is in Adobe's print menu and not the Ricoh print driver menu.
              • teebee1234
                • 1670
                As others have mentioned, I'd bet anything that they're using the 'Ricoh Class Driver".
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Death to the "Ricoh Class Driver" and WSD ports.
                  I had a customer try using both of these (the IT guy is a TOTAL jerk) with Equitrac. He thought he knew it all. NOT.
                  Drove us nuts until we found the problem. Fortunately, it was only an hour or two.
                  • Ottawatech
                    • Feb 2015
                    • 63
                    X2 on the drivers and the WSD port. Also have found that, as above, if the PDFs haven't been flattened or de-layered, a relatively small file can baloon - 5 Mb can become 100 Mb. Right-click the printer icon in the system tray; you'll see the file size.
                    Tim
                    Nothing works quite so well that I can't totally disable it by trying to make it a little better.
                    • qbert69
                      • Mar 2013
                      • 1152
                      If the PDF is too complex and layered (not flattened) it can "balloon" when print processing.
                      Go download Bullzip:
                      Download PDF Printer
                      Download the "Community Version" which is free and can be installed for less than 10 installations.
                      The "Community Version" download link is below the price list.
                      Bullzip WILL recompile and flatten the PDF as much as possible and simplify it!
                      REACH FOR THE STARS!!!
                      Konica Minolta Planetariums!
                      • ApeosMan
                        • Nov 2009
                        • 183
                        WSD is horrible, I've had issues with it on multiple vendor devices, it's really flaky.
                        Also in regards to Ricoh and Xerox etc 'Class' drivers the reason why they create large spool files is because of the lack of PCL 6 compression that a model specific print driver would have.
                        • ApeosMan
                          • Nov 2009
                          • 183
                          Hmmm I try to avoid 'Print as Image' as I've found it usually slows things down, maybe I'm wrong, anybody else found this?
                          • ApeosMan
                            • Nov 2009
                            • 183
                            Originally posted by terramobil
                            My experience is, that the LPR Port in many cases is much faster as the TCP/IP Port is.
                            I suppose the reason may be that when printing via LPR the printer may spool the entire job to the printer's HDD before printing (if it has one) which may in turn may speed up the page buffering whilst printing depending on the design of the printer.
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              Funny, I remember slow PDF printing being an issue for probably 15 years now.
                              I had the same problem with Canon machines back then.
                              The worst part is when you get the almost inevitable "Our old printer worked fine. Your salesman said this new one would be faster, not slower.".
                              It's tough to explain things like PDF flattening to someone who has no idea of what you're talking about.
                              PDFs can be produced in so many different ways, and from so many different sources, that they're almost impossible to get a handle on. It's like trying to nail down jello.
