Aficio 3025 dirty lines on back page
  • tullio
    • Feb 2012
    • 268
    Afico 3025, changed drum, however see a dirty fated band on back of the page, leading edge side. most of time it only appears on the first page of copies. any clues. thanks.
  • mikadonovan
    • May 2008
    • 2931
    Re: Aficio 3025 dirty lines on back page
    There's only one fix for that, a developer change and be sure and set developer according to the manual.
    NEVER ASSUME ANYTHING
      • 37480
      Dirty transfer roller. Replace it. There is also a setting in SP for transfer roller cleaning. Set it after you have a new roller installed.
      • jonhiker
        • 661
        Check the paper transfer roller.
        • ronald2020
          • May 2009
          • 31
          And take note use original toner you will not have these issues
          • Polarbear
            • Feb 2012
            • 1070
            +1
            Wrong toner - screws up the dev - dirty background on back of copies....
            Press the GREEN button!!
              • 37480
              Originally posted by Polarbear
              +1
              Toner right or wrong, if you push the transfer roller to far past recommend PM, you will get about 1/2 inch of background on the lead edge of the back of the paper.
              • mikadonovan
                • May 2008
                • 2931
                I used to have a blue million B039's in the field, and they suffered from this issue. When you replace the transfer roller and turn on transfer roller cleaning and it doesn't fix it, refer to my first post.
