Ricoh Aficio MP7500 changed paper size Tray 1 and LCT to A4
  • mterrero
    • Sep 2011
    • 60
    [Misc] Ricoh Aficio MP7500 changed paper size Tray 1 and LCT to A4
    Aficio MP7500
    Tray 1 and LCT changed from Lettler size to A4,
    SP5-131-001 doesnt affect,
    any idea or setting I must check
    Thanks for your help
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh Aficio MP7500 changed paper size Tray 1 and LCT to A4
    Program tray paper size in user tools.
    NEVER ASSUME ANYTHING
    • service_man
      • Jul 2012
      • 59
      Try to change FW
      Maybe is blocked in the system, and is not recognized LTR format.
      • mterrero
        • Sep 2011
        • 60
        Problem solved,
        Paper Size
        SP5-959-001 ( Tray1 )
        SP5-959-005 LCT ( Tray 4)
        how this changed by itself, ???? Mistery
          • 37556
          Originally posted by mterrero
          Problem solved,
          Paper Size
          It is in the Service Manual. Maybe someone did a memory clear as A4 is the factory default.
          • Iowatech
            Not a service manager
            • 3930
            An additional guess - if construction or energetic storms or something else disturbed the the local electric utility's lines, the voltage supplied to the machine from the outlet it is plugged into may have varied enough that wrong and stupid things may have happened.
            That was a bigger problem years ago, and the newer machines are robust enough that it's not that big of a deal now. But I still see that every once in a while.
            • fuwei2422
              • Nov 2014
              • 49
              SP5-959-001
              SP5-959-005
