what is the fuser reset code for a sc-542 (sp-5200)
stil inter with "c" 107 (stop)
gary
Most likely not as this is a printer and the Operation Manual picture of the control panel does not show a Clear Mode or Stop key. Most of the newer printer models do not have instructions in the service manual for entering SP mode. You are given that information when you are trained on the model, either classroom or online. Clearing fusing codes is in the service manual once you are in SP mode.
