mpc2500 sc553
  • Mark Bbb
    • Jun 2012
    • 1662
    mpc2500 sc553
    I know this has been treated many times before on this forum, but is there an other solution than to replace the fusing unit with a new one?
    I replaced the thermophile inside the machine, and al the parts of the fusing unit...
    Man, how thankfull i would be if anyone give me that hint
    Nice weekend!
    Mark
  • Polarbear
    • Feb 2012
    • 1070
    Re: mpc2500 sc553
    Nice weekend!
    Mark
    Mark
    The one thing that stands out from all the posts on this topic, is that replacing the unit is the only permanent fix.
    If you compare the cost of the parts + callbacks + labour and downtime: where is the saving?
    Not to mention testing the customer's patience to the point that they demand the machine be replaced citing reliability being flaky?!
    Some techs believe that the fusing frame becomes skew over time that it causes all the unexplained codes - I don't know for sure.
    If it was me - i'd replace the unit and know that it IS fixed.
    Press the GREEN button!!
    • TonerMunkeh
      Professional Moron
      • 3865
      Re: mpc2500 sc553
      Unfortunately not. You can replace every single part of the fuser and it will STILL code. Save the heartache, fit a new one.
      Hit it.
        • 36796
        Re: mpc2500 sc553
        If you have another machine, swap out the fusing units. If the problem moves with the fusing unit, the fusing unit is bad. If the problem stays with the original machine, check/reseat CN 257 on IOB, replace IOB, replace PSU.
        • Mark Bbb
          • Jun 2012
          • 1662
          Re: mpc2500 sc553
          Thank you guys for responding so quickely...
          I give up and will replace the unit, but, do you know where to buy a cheap one, here in Europe?
          • Mark Bbb
            • Jun 2012
            • 1662
            Re: mpc2500 sc553
            i've already swapt and the problem stayed with the machine... But i have had this also with another machine and it only went away with a whole new unit...
            • bob marley
              • Jan 2012
              • 1339
              Re: mpc2500 sc553
              1- Defective PSU
              2- Defective IOB
              3- Defective BCU
              Live for yourself and you will live in vain. Live for others, and you will live again
              • Zaxxon
                • 608
                Re: mpc2500 sc553
                Originally posted by bob marley
                1- Defective PSU
                2- Defective IOB
                3- Defective BCU
                Cheaper to buy a new machine then this box i old reached 10 years anniversary I believe.
                Please start you post with brand, model, problem.
                • Greyfox1223
                  • 8
                  Re: mpc2500 sc553
                  Nice weekend!
                  Mark
                  you should replace the Hot roller PN#AE010054 to solve the SC553
                  goodluck...
                  • Polo-022
                    • Sep 2007
                    • 481
                    Re: mpc2500 sc553
                    This little thing makes the difference : ΑΒ01-3722.
                    A fuser maintenance item!!!
                    No more SC 553.
                    • NeoMatrix
                      Senior Tech.
                      • 3514
                      Re: mpc2500 sc553
                      .... From memory.
                      I believe one of the thermal exhaust fans would spin slowly causing a false SC code.
                      I can't remember it was the fan under the operation panel, or the fan at the upper rear side of the duplexer door.
                      HTH
                      • stani
                        • Jan 2013
                        • 49
                        Re: mpc2500 sc553
                        I had some mashines, where I replaced only the belt and got this error. I could solve this error without changing the whole fuser unit. Changing the orange foam roller AE010054 and the gear with one-way clutch that drives it ΑΒ01-3722 solved it. Thanks to Greyfox1223 and ​Polo-022 from this thread! If you use the whole fusing service-kit B230-KFUSA, and not only the belt, you dont see the error 553 at all.
                          • 36796
                          Re: mpc2500 sc553
                          Judging by the limited number of posts, you apparent are new here. Many of us older techs do not appreciate grave robbers. Any technical thread that has been over a year since it was started and over six the last post is considered dead and buried.
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            Re: mpc2500 sc553
                            But i'm not buried at all, thank you...
                            sc553: do a reset not only in SP but also by installing a original fuse.
                            There is a way around, with a very simple doorswitch...
                            The procedrue is also somewhere on this forum.
                            • fshead
                              • 2356
                              Re: mpc2500 sc553
                              i dont think he was talking about you.
                              As far as door switch reset i made one for the mpc3502 fuser unit.
                              A mp 2550 thermister connector and old micro door switch and 2 feet of wire.
