Document feeder not working (MP 4002sp)
  • sharpmind
    • Sep 2009
    • 478
    There is no response in the feeder when original is set and when the Green button is pressed. All mechanisms are working during output check. I tested the document feeder in the other machine and it is working fine. Scanner board and document feeder detection sensor are also changed and the Lens unit assembly is also tested but still same problem. Any ideas?
  • tjvincent
    • 280
    Re: Document feeder not working (MP 4002sp)
    Try a power supply
    • cba
      • Apr 2016
      • 4
      Originally posted by tjvincent
      Try a power supply
      please check the sensor which is under feeder
      • sharpmind
        • Sep 2009
        • 478
        Try a power supply
        Check the voltages in the power supply unit. No 5V measured in the connector going to the scanner board unit. Problem solved!
        • sharpmind
          • Sep 2009
          • 478
          Try a power supply
          Check the voltages in the power supply unit. No 5V is measured in the connector going to the scanner board unit. Problem solved!
