resetting admin code on a savin 8025 thought it was 7810but not available there any help
savin 8025
Log in as supervisor with no password to reset the admin password. If the supervisor has been changed, it's a new NVram I'm afraid...It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Machines when extended security do not have SP 7810
Try logging in as supervisor and no password. (The supervisor logon can only change an admin password)
If unable to login as supervisor and the admin password is unknown. The NVRAM must be replaced and DO NOT upload the nvram data to the SD card because the passwords will carry to the new NVRAMComment
If the other suggestions don't work you can try to reset the System Settings to default. Press the counter/user tools button, press and hold the # key and press the System Settings button on the touch panel and then confirm the reset. I'm not sure if this resets the password back to default or not, but it will turn off the user security settings (by resetting to the default setting).the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
note to self...... really got to start that little black book of tips and tricks.Comment
I stumbled across it totally by accident. I usually enter tech mode and access the super secret settings mode by pressing the # key so I can access everything if need be. I was entering the system settings mode one time and through habit hit the # key when I did it and viola!the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
