Pro C 5100 issues
  • barber782
    • Aug 2011
    • 279
    Pro C 5100 issues
    Hi everyone,
    Iv got problems with a pro c5100 machine. I have recently replaced the transfer belt and sensor assembly. After replacement i have done the procedures shown in service manual, but have had no success. The colour registration is all off, and even doing auto colour reg calibration fails, and all other calibration setgings fail within service mode. Also every now and then I get a sc285-00 code.
    Any support would be great.
  • mita
    • Sep 2010
    • 87
    Re: Pro C 5100 issues
    I had a similar issue on a Proc5110 found that when I cut the tie band on a two wire jumper between the pcb's in the transfer belt assy the issue went away.
    • barber782
      • Aug 2011
      • 279
      Hi. Tried cutting the tie for that wire but still no luck. Im getting really bad colour reg issues
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        any codes???????????
        Mystic Crystal Revelations
        • barber782
          • Aug 2011
          • 279
          Error code sc285-00
          • Timmytronic
            • Oct 2010
            • 249
            Originally posted by barber782
            Error code sc285-00
              dead thread grave robber.
              diff machine...
              start your own new thread
              • Timmytronic
                • Oct 2010
                • 249
                diff machine...
                Seriously Phil. Get a life!
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Colour registration problems clean id sensor if no good do laser line procession
                  Regards Mark
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    diff machine...
                    Be nice gents
                    Regards Mark
                    • Timmytronic
                      • Oct 2010
                      • 249
                      • Bricorley
                        • Jul 2017
                        • 41
                        I was having a registration issue a couple weeks ago. No matter what i did the machine didnt respond. I finally said F it and tried doing a Memory Clear...registration was perfect after that. You will have to fix the D2 jam and initialize the fiery in SP mode
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          OK did you do registration set up in user tools
                          Sensors must be clean
                          Also are the colours solid on the transfer belt when stopped on run
                          With out looking in manual I THINK it's sp2111 start with D, C, B, A start with D finish with A twice
                          Please don't do memory all clear unless it's a must and if do please back up nvram 1st or you have a long job in putting sp settings make sure you have a copy of the factory sp settings
                          Regards Mark
                          • Timmytronic
                            • Oct 2010
                            • 249
                            Hiya
                            Checked pattern and all is well. The magenta is on the screw by about a 1.5mm from top to bottom, changed the whole PCU as mentioned, done Force Line adjustment and it fails on C and D only. I guess it must be the laser unit but its such a big job
                            Just quickly, am I right to say the only skew adjustment for the colours is SP2104?
                            Oh I did have to reset the memory but uploaded the memory first for settings, but not uploaded them back yet as I know the sensor setting and need to get it working right. It did give me a colour registration confirmation once I had done that but still at an angle for the magenta and fail on C and D.
                            If there is another adjustment on the skew that would be great to know as I am lost now :-)
                            Thanks Tim.
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              Hiya
                              Thanks Tim.
                              Hi Tim ive had failed before start on D if fails come out service mode then go into printer service mode do colour test print go back into service and try D again i had one I done rhis 3 times then it came back in line then c and so on
                              Good luck
                              Regards Mark
