Savin C4540/ricog c4500 open door error
  • jper34
    • Sep 2011
    • 225
    Hi Folks,
    I thought this wouild be easy,....the panel indicates right door open, I ohmed out front door/right door interlock switch..seems.o., I also swapped the interlock with as far as I know, a good used swithc(I also ohmed this one out, before installing it)..still same problem, all the other switches seem good,if I open bridge door, it will indicate its open,or if you remove fuser assem., seems like 2 photo-interrupters seem to be working fine..I briefly check power supply boards for any blown fuses..what could I be missing....? any help greatly appreciated..thanks in advance !!!
    Jaime
    Indep. Copier Svc.
  • duplicators
    • Apr 2016
    • 63
    Re: Savin C4540/ricog c4500 open door error
    Originally posted by jper34
    Hi Folks,
    Jaime
    Indep. Copier Svc.
    change the switch front door
