Ricoh MP C2500 Scanner setting issue
  • CJohnson
    • Jul 2025
    Have a MP C2500 that every time you press the scanner option, the screen defaults to File Store instead of the scanner address book. You can press the "File Store" button at the top of the screen and then cancel and it will no longer be lite and the address book comes up. Once the screen times out, it goes back to this configuration. I have turned the Delivery Option for ScanRouter delivery off but didn't change anything on the scanner option screen. I know it is a setting, but have been unable to determine where to make the change at, Can someone please point me in the right direction while I still have some hair left? Thank you for any advise that can be offered in advance.
  • zed255
    How'd ya manage that?
    • 1024
    Re: Ricoh MP C2500 Scanner setting issue
    Choose the options you want as default from the scanner option, then hit the 'Program' key and choose 'Set as Default' (or some such wording) off the touch screen and finish by agreeing to the confirmation prompts.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      See: Defaults.pdf
      • CJohnson
        I thank you, my brother thanks you, my daughter thanks you, but most of all, my wife thanks you cause I get to keep what's left of my hair. I knew it was something simple, just was not thinking in the right frame of mind. Kept looking through the settings.
        Thanks again.
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Originally posted by ruben
          See: [ATTACH]32868[/ATTACH]
          PDF is not working for some reason, see: http://support.ricoh.com/bb_v1oi/pub...7/B7887707.pdf (page 150) instead.
