RICOH AFICIO 1022 cannot get the image to line up on duplexing
  • TEKK09
    • 142
    Can get both sides perfectly centered if placed on glass, but then regular copying is off. Can get both sides within 2~3mm of perfectly centered image using ADF, but then regular one-sided is off.
    Did these adjustments:
    page 6-36 - internal test print "Registration - Leading Edge/Side-to-Side" adjustment (successful)
    page 6-41 - "ADF Image Adjustment"
    What am I missing?
  • LNorris
    • Sep 2008
    • 645
    Re: RICOH AFICIO 1022 cannot get the image to line up on duplexing
    Make sure the Duplex Margin, in User Tools > Copier Features, is set to 0 (default to 5mm / 0.2inch).
    • TEKK09
      • 142
      YOU NAILED IT!
      That adjustment shows up at the bottom of the display when the duplex button is touched. Another mystery solved. Thanks a million...
