MP C2800
  • CrapAimer
    • 296
    MP C2800
    Hi All
    Have a Ricoh MP C2800 which cant find a IP Address on DHCP, i have change the controller board, still the same, put a wee MP 201spf on and its working ok. anybody ever came across this.
    Regards
    George
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MP C2800
    Print off a config page. If IEEE802.11x Authentication for Ethernet is active, disable it in interface settings. It's locking the NIC out. If you put it on a static IP crossovered to your laptop, does it ping?
    Hit it.
    • zed255
      How'd ya manage that?
      • 1024
      Re: MP C2800
      Have you tried resetting the NCS with SP5-801-11?
      • mbolduc
        • Jun 2015
        • 53
        Re: MP C2800
        Make sure 5985-01 is on
        • Iowatech
          Not a service manager
          • 3930
          Re: MP C2800
          What operating system are the computers the machine is hooked up to using?
            • 36855
            Re: MP C2800
            If you disconnect the C2800 and connect your laptop does the laptop get an IP form the DHCP. If not, either they are not using DHCP, their DHCP is set to only accept requests from registered MAC addresses or there is a bad port on the switch.
            • CrapAimer
              • 296
              Re: MP C2800
              Thanks for all the help sorted its was the IEEE802.11x Authentication
              George
