SC 672-11 On Ricoh MP C306
  • JayWilbur
    • May 2016
    • 3
    [Error Code] SC 672-11 On Ricoh MP C306
    I am getting this error code only if the machine is in sleep mode and someone sends a print to the machine. I have had success restarting the machine and sending a print job, and it prints successfully throughout the time the machine is "awake". But once it goes to sleep and someone sends a print job, this code is thrown. I have double checked the wires from op panel to board. Also, I have checked the dip switches on the op panel, and everything is as it should be. Has anyone seen this? FYI this machine is about 2 weeks old.
  • LNorris
    • Sep 2008
    • 645
    Re: SC 672-11 On Ricoh MP C306
    i would update firmware first.
    • Production Tech
      • Jan 2015
      • 5
      Don't update the package firmware. There is a bug in it and it will lock up at the Cheetah app. The only fix is to replace NVRAM which is on back order with no ETA.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        I would make sure all machine frimwar is current, java is current, and then update the SOP frimwar and all it's APP's
        Mystic Crystal Revelations
        • bob marley
          • Jan 2012
          • 1339
          had the same problem solved after update firmware
          Live for yourself and you will live in vain. Live for others, and you will live again
