MPC 8002 / 6502
  • Timmytronic
    • Oct 2010
    • 249
    MPC 8002 / 6502
    Hi. I have this silly problem which I can't get round. The machine says PCU replacement required and it has done it on this machine before way before it's due and even the counter said it was not halfway done. Back then I did all what to do in the manual to reset it and it would not have it so eventually I reset the Engine memory. This cleared it but then I have to spend ages putting the data back in for other stuff it resets.
    It's happened again on the yellow unit now and it's exactly the same reading as the cyan say but that is fine. The lub bar is fine also. Before I reset the engine and go bonkers am I missing something that I need to reset that the manual is missing?
    Sorry to ask such a basic thing.
    Thanks loads.
    Tim.
  • Timmytronic
    • Oct 2010
    • 249
    Re: MPC 8002 / 6502
    MPC 8002. Manual reset of parts is SC 3701. That's done it. Doh!
    • MIKON
      • Jul 2015
      • 187
      Re: MPC 8002 / 6502
      After replacing the pm parts with machine off.
      Turn on with bypass tray open.
      Reset desired counters.
      Close bypass door.
