I have a newly installed MP 2550. The customer does not have a dedicated fax line. They have voice, answering machine, and now a fax on the same line. Ricoh tells me this combination will not work. Manual recieve is not an option because customer is out of office a lot, and machine is all the way across the room from desk phone. Customer bought a fax switch, and still does not work. Any ideas?
Fax problem with MP255oB
You said that it now has a fax on it-is that the Ricoh?
Does the phone/fax/coffee maker/office cleaner/thingy work with a 'regular' fax machine?
I have not been a fan of these fax switches, but sometimes people have 'used them for 500 years without any problems' yeah, yeah, I know.
You may have to mess with the bit switch settings, like baud rate and maybe turning ECM off, to see what works.
The Ricoh's usually have a 1000 settings to adjust-sometimes a good thing and other times a bad thing.Bachelor of Science in Information Technology, Comptia A+, Comptia Network+ -
Ruggedawg444
Customer has a little brother fax machine that works fine. I've spent half a day adj bit switches, and on the phone w ricoh trying to resolve this. Turned off ECM.Comment
You might want to check the phone line voltages coming out of the "fax switch." (what is that anyway?) If it's a passive device (i.e. not powered) there could be some voltage loss in the circuit preventing it from being recognized as a ring.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
Cobiray, the little devices are powered and everything plugs into them. They determine the call to be either voice or data and route the call. I just wish that customers would get a dedicated fax line and these problems will disappear.
Ok, since the Brother fax works, I don't see why the Ricoh wouldn't work, given the proper settings.
Were you able to match the Brother settings, via its internal printout, to the Ricoh's settings?
Also, does the switch manufacturer have any suggestions for items that don't work? Do they have a website for support?
I'm actually leaning towards something simple, but damned if I know what that would be.
Did you adjust down the baud rate to match the Brother's? Or is the Brother a Super G3 @ 33.6kbps?Bachelor of Science in Information Technology, Comptia A+, Comptia Network+Comment
E Winter
Ok, since the Brother fax works, I don't see why the Ricoh wouldn't work, given the proper settings.Comment
Make sure that the phone switch is the first thing plugged in from the wall line. If there's anything that's taking the wall line from the switch it will throw everything off, especially the fax.
Also make sure fax SP 2-103-007 is set to One. That is the number of rings for the machine to detect whether a call is a fax.
Good luck with this.Comment
I hate to backtrack over what's already been done, but have you tested the fax plugged directly into the phone line?the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
The Brother has the distinctive ring ability, the Ricoh doesn't.
Run a phone line from the output of the Brother to the input of the Ricoh.
Set the Ricoh to manual recieve and the Brother to the original settings.
Gives the customer the ability to recieve faxes and still use the lan-fax on the Ricoh.
The only other alternative is a dedicated analog fax line that the Ricoh requires.Why do they call it common sense?
If it were common, wouldn't everyone have it?Comment
I'd just say get a dedicated line, makes for a lot less headaches.
I had a good fax call a couple of months ago, the customer's fax wasn't working... they'd plugged a RJ-11 into an RJ-45 port. Had to end up buying them an adaptor but apparantly this had been working for 3 years solidly! :OIntel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
Asus P5E-VM HDMI
4GB (2x 2GB) Corsair XMS Xpert II RAM
ATi Radeon 4870 512MB GFX Card
2x 74GB WD Raptor Sata HDD (RAID 0)
500GB Seagate Barracuda Sata II HDD
500GB Hitachi Sata II HDD
600W500att OCZ PSU
-TOTAL HDD SPACE 1148GB-Comment
E Winter
Mr T
Ricoh fax issue
Ricoh devices do not contain an internal fax switch, instead they rely on the line having a telco service activated called "distinctive ring" which provides a different ring signal for an incoming fax as opposed to a voice call allowing the fax to recognise and automatically recieve a fax, but also ignore incoming voice calls. Ideally the fax should be connected first in the phone/ fax line and any devices such as phone handsets and message recorders connected via the EXT/phone passthrough connection.Comment
