MPC3001 Error SSL Negotiation failed
  • AleLeader
    • Oct 2012
    • 29
    I have MPC3001 and i have account GMAIL.
    I have configure all and work all (send email) for 2 month.
    I have configure SSL / Certificate end 2018 but when send email :
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MPC3001 Error SSL Negotiation failed
    Make sure the firmware is up to date, there were some SSL updates to this model.
    You can also use the Gmail relay instead, if you are sending to another Gmail account: https://support.google.com/a/answer/176600?hl=en
      • 37515
      ruben you beat me to it.
      Make sure you are installing the proper certificate. I have found that if you are using Windows 8 or older, the certificate exported from either IE or Firefox will be expired. Use a Windows 10 computer to export the certificate. Use site certificate not device certificate. Also if they are using SSL for anything else on the C3001, then they cannot use it for email.
      • AleLeader
        • Oct 2012
        • 29
        Certificate is ok .
        For 3 month work all .... now Error SSL Negotiation failed and not have change nothing for MPC/Network.
        Gmail Update?
