Ricoh MPC4501 code J001
  • absindy
    • Jul 2015
    • 6
    This Machine keeps getting J001, I do not see any jam paper and I cleaned all the sensor, still as soon as when machine is turned on J001 shows on display and also shows how removed paper jam from the machine but there is no paper
    jam any idea what else is causing this code?
    Mike
  • Wild Bill
    • Jul 2005
    • 774
    Re: Ricoh MPC4501 code J001
    Input codes, test each sensor
    Izzy
    • duct tape
      • Jun 2009
      • 87
      I've found that the bridge unit door switches are the number one cause of this . I keep on hand those cause when you see 01 jams on the report that is most of the time the fix. Other than that it could be any of the machine or deck door switches. Until the machine sees a door switch cycle on and off it won't clear the jam.
        • 37375
        J001 is a jam detected at power or when a door is closed. If it is not clearing one of two things is happening. Either there is a scrap of paper on a jam sensor or one of the door switches is not working. One other possibility is that there is a sheet of paper partially fed from one of the paper trays that is out far enough to get to the feed sensor but not far enough to be visible when you open the right side door.
        • absindy
          • Jul 2015
          • 6
          Hi
          It looks like is the bridge unit door switches problem, does anybody have the part number on these switches.
          Thank you
          Mike
          • Counsel
            • Aug 2011
            • 530
            This is the switch number off a 4502 bridge unit but i am pretty sure all the switches are the same going back several generations. AW500023, if your careful you can remove the switch pop the two edges up and open the switch, there is a spring, and a contact plate inside usually cleaning the contacts takes care of it. The other thing that may simply fix it without opening the switch is look at the two prongs on the switch were the wire connects if they are black scrap them off with a tiny flat screwdriver so they are shiny, a lot of these the contact greese they use gets gummy and the connection is bad, otherwise just replace them if you like.
            • absindy
              • Jul 2015
              • 6
              Thanks, I will try it.
              • Iowatech
                Not a service manager
                • 3930
                On some of the older bridge units, I used to build up the post that activated that safety switch. A piece of thick tape or an epoxied on washer usually did the trick.
                If I remember correctly the MPC 2050 (or 2550) had a switch similar to that for the rear right hand door interlock, and I had one of those that had trouble staying activated too.
                Apparently the plunger on that type of switch occasionally is just the tiniest bit too short.
                  • 37375
                  You can also use a business to make a spacer to go under the switch so that it rides slightly higher.
