Ricoh Aficio mp6001, Toner Supply Problem
  • tullio
    • Feb 2012
    • 268
    Ricoh Aficio MP6001, Toner Supply Problem
    Ricoh Aficio MP6001, Low density Copies (lights Copies)
    Problem: TonerToner supply unit on top of developer unit changed
    3- Toner Hooper Changed
    4- Drum Unit, Drum, Charge Corona Unit
    5- Developer/toner supply Motor Changed
    6- Transfer Unit Changed
    7- High Voltage power pack ( Drum and Corona ) changed
    Test:
    Making forced toner ( toner is not supply on the developer )
    I make a force toner supply manually opening the developer unit and the copies became dark ( Perfect copies ), for son reason the machine is no supplying toner automatically
    Can someone Help me
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: Ricoh Aficio mp6001, Toner Supply Problem
    bad toner supply clutch. it's part of the developer drive unit...................
    Mystic Crystal Revelations
    • Guest
      Hi.
        • 37383
        Visually check that there is toner in the toner hopper. If not, use output checks to run the toner bottle motor and check that the bottle rotates. If it rotates but no toner goes into the hopper, there is a problem with ether the toner throttle or the toner chuck is not opening the inner valve of the bottle. I have had the metal guides that open and close the chuck become deformed and have the chuck not open the bottle.
        • Polo-022
          • Sep 2007
          • 484
          When "toner is not supplied automatically" the toner empty sensor must be replaced.
          My 2 cents....
          • tullio
            • Feb 2012
            • 268
            sensor td ?
            sensor td ?sensor td ?
            • Mark Bbb
              • Jun 2012
              • 1662
              Hi,
              Light copies after all these replacements.
              Did you follow exactly the procedure of the service manual?
              I bet you didn't...
              hmm?
                • 37383
                My 2 cents....
                Did you read what he has already replaced? The sensor is part of the complete toner supply unit.
                  • 37383
                  Originally posted by tullio
                  sensor td ?
                  I believe that he was referring to the sensor on the side of the toner supply unit that detects whether there is toner in the supply unit and if not then the toner bottle motor is turned.
                  Just thought of one thing to check, I have occasionally encountered cases where the toner supply sensor is not properly plugged in to the machine. It is one of the 2 cables you have to unplug to remove the development unit and is easy to not plug in properly, voice of experience.
                  • Polo-022
                    • Sep 2007
                    • 484
                    Oh noooo...!!! My apologies mr slob.
                    Yes, it is included and everything that he replaced was totally newww.
                    Eh?....
                    • Tonerbomb
                      • Feb 2005
                      • 2589
                      Originally posted by Flavio.cardoso
                      Hi.
                      Yes I'm quite aware of this TSB, I use it on multiple 01 series and also on 02 series machines because I have a
                      customer that runs 50k/month + on many of these and the fill rates are less than 4%. based on the list provided and manually toning up works I question the supply clutch, and possibly the IOB and BICU........................
