mpc2050 jams at regi. sens. log -17
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    It Happen sometimes, always just before the regi. roll's without creases.
    The attachment of an earlier thread says the 2 one way bushings of the paper feed can cause these jams.
    There is not a regi clutch present, it is motor-feeding, so it has to be the one way roller gears?
    It seems it only jams with tray 1, not tray 2...
    so the only way is the one way ?
    Greetings,
    Mark
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: mpc2050 jams at regi. sens. log -17
    Try changing the spring clutches on the paper feed first. They are a bit of a bugger to get at on tray 1 though.
    Hit it.
    • Mark Bbb
      • Jun 2012
      • 1662
      Tonermunkeh: I think you mean
      • Byrne
        I agree with feed clutch. I've had this and if you can manage to get the spout of a tin of solvent in to the clutch and give it a squirt, and it feeds okay, order a clutch and they are a fiddely to fit but do-able. And it will get you out of the whatsit until you can fit one.
        • Mark Bbb
          • Jun 2012
          • 1662
          My training material is saying that there are no paper feed clutches in this machine; there is a motor and there are two one way gears or bushings / tray.
          So what is that you mean?
          Could it be that the motor must be adjusted for "staying on for a longer period of time"?
          If you are just guessing, don't forget to mention it please!
          • Mark Bbb
            • Jun 2012
            • 1662
            I checked the part catalogus, there is no paper feed spring clutch in this machine, only roller clutches.
            So can you please be more serious when replying?
            Thank you.
              • 36816
              Thank you.
              D0391166 & 64 have been replaced by D1051166 & 64. They are gears with a one-way spring clutch. Parts catalog descriptions can be misleading.
              • Mark Bbb
                • Jun 2012
                • 1662
                I love my pussycat!
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Byrne, how wright you were. Indeed, the clutch-gears have a spring on it. Thank you!
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    So after blatantly disputing the fact this machine even has spring clutches you are rude enough to say people are giving you duff advice? Really.
                    Hit it.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      Yeh, really!
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        So guy's, thank you all! I have opened the machine, tray 2 is no problem, but tray 1 seems to be really hard to remove the paper feed unit ...
                        May I ask you how (im)possible it is to remove and re-install the paper feed motor ass'y off tray 1?
                        Thank you in advance for your answer ...
                        Greetings,
                        Mark
                          • 36816
                          Paper feed motors remove from the back of the machine.
                          • mohan
                            • Oct 2013
                            • 87
                            Hoi,
                            Greetings,
                            Mark
                            It's been awhile since I worked on these, but if I remember rightly, the user is required to lock down the lift-plate when loading paper in the tray. If this is done too forcefully, it can cause the right hand slider rail for the tray to deform, causing the feed roller to rub against the paper guide and cause jams. A symptom on testing is a sort of groaning noise just before a jam.
                            • mohan
                              • Oct 2013
                              • 87
                              PS. A good way to confirm whether this is indeed the cause is to place your hand on the front RH side of the tray and slightly push it upwards when the groaning sound starts.
