af 1022
  • Gab
    • Aug 2015
    • 671
    af 1022
    crack sound . It looks that it comes from the gears that transfer movement to the fuser gear. I checked that gears and they are ok (no broken etc) Also they turn with no problem ( i turned them throgh main motor. It is not the fuser unit , i checked it also it tried with an other fuser unit and the crack soun remains. Any idea?
  • rthonpm
    • Aug 2007
    • 2859
    Re: af 1022
    Are the bearings on the heat tube and press rollers lubed? I've heard a lot of these boxes creak when the bearings begin to wear or the grease begins to dry out.
    Sent from my BlackBerry using the Android app.
    • sandmanmac
      • 3981
      Re: af 1022
      He did say he tried another fuser, but who knows where that one came from and how long it had been sitting around.
      It sure would be helpful to know if it passes paper and/or what the copy quality looks like?
      I'm leaning towards PCU, but I'm a long way from Greece, so I can't say for sure
      • gear13z
        • Sep 2011
        • 68
        Re: af 1022
        is the hot roller compatible or genuine?
        .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
        • Gab
          • Aug 2015
          • 671
          Re: af 1022
          The fuser unit i swaped is ok. I checked the old fuser unit and it is ok. The image i ok.
          It stops the paper on fuser.
            • 37529
            Re: af 1022
            If it sounds like a coffee percolator, it is the fusing unit bearings. Get some high temperature grease.
            • StephenB
              • Aug 2015
              • 244
              Re: af 1022
              Have seen lots of these, you may need new (greased ) bearings. Also check how the bearings set in the unit, many times the plastic breaks out causing improper alignment of the hot roller gear and the copier side gear.
              I have use 450 upper bearings with the ring on the bearing, cut 1/3 of the bearing ring off, and the ring then secures itself on the metal frame instead of needing a plastic frame.
