Ricoh Aficio 1035
  • Fierhawk
    • Sep 2025
    Ricoh Aficio 1035
    I was called out to this machine for toner. When I got there it didn't need toner. I was packing up my tool case getting ready to leave when I looked at the machine it was saying a cover was open. I could open up any cover and it would tell me what cover is open, but when I shut the covers it would still say that there is a cover open but wouldn't show which one. I first cleaned the LD unit. When I turned the machine back on it came up like it was going to work but then it came up saying a cover was open but still not indicating which one. After that I cleaned the connection on the board on the LD unit, and then cleaned the main switch connections. After this I was able to get it to work. I was just wondering if anyone else has come across this problem before and if there is something I need to do for it? Any help appreciated, thank you.
  • Jimbo1
    • Mar 2008
    • 845
    That switchbank right above the fuser will do that for you. It has a connection on one of them that gives that indication. You can also get that if you get a bad connection on the ribbon cable from the laser unit.
    We normally just replaced all those switches but I believe someone here said it was the middle one.
    May be wrong on it being the middle so don't hold me to it.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • lvsb
      • Aug 2008
      • 70
      This is a common problem with this series machine.
      The 5volt interlock switches have failed replace the door switches.
      • Fierhawk
        • Sep 2025
        Ricoh 1035
        I did clean all the connections on the LD unit and it worked until I put the cover back on. Actually I just unplug the connections then plugged them back in. I then to a contact cleaner to the connections as well as to the front door switches; still had the problem. Because I noticed moving the door switches I could get the copier operating but not permanently; I decided to take the switch assemmbly (main and front door switches) to the office and try on another copier when I found my problem. I failed to seat the middle switch correctly. Thanks for you help.
        Tom
        • FRIDGEMAGNET
          • Aug 2007
          • 377
          If you are in a fix with these switches they can be pulled apart and cleaned.
