mpc2050 removing paper feed unit tray 1
  • Mark Bbb
    • Jun 2012
    • 1662
    Hi there!
    To remove the paper feed unit of paper tray 2 is rather easy, but I don't even know how to start with the one of tray 1!
    Can you give me any advice?
    Thank you in advance!
    Greetings,
    Mark
    • 37365
    Re: mpc2050 removing paper feed unit tray 1
    If it does not move at all, you have a problem with the latch. Remove tray 2 and look at the latch to see if you can come up with a way to release tray 1 with a spring hook or screw driver from below, might be able to remove the face plate from tray 1. If the latch releases but the tray will only come out a couple of inches, you might have a rear side fence that has popped up out of its guide or is broken and is hitting the bracket for the paper out sensor. You may have to force it. You will possibly have to replace the paper out sensor and straighter the bracket.
    • Mark Bbb
      • Jun 2012
      • 1662
      • zed255
        How'd ya manage that?
        • 1024
        Tray 1 paper feed unit comes out much like the tray 2 location, with the difference being:
        You need to remove the tray 2 unit first, and though it looks impossible it will in fact come out with a little re-orienting down past where the tray 1 unit was located.
        • turbojetboy
          • Aug 2009
          • 279
          Its not that big a deal, but you will want to have a new "spring clutch" on hand. I tend to replace both trays "spring clutches" whilst im there. It usually takes about an hour. Its the spring and shitty plastic gears that the clutch spring works with that play up on this model.
          • logrady2331
            • Feb 2011
            • 301
            Definitely replace BOTH spring clutches while it's apart. I find it WAY easier to take the power supply out of the machine. It only takes about five minutes to take it out and the feed motor assemblies are a heck of a lot easier to get out and back in. Make sure you get the feed unit (number one) ALL the way in. It is pretty easy to get it a little crooked and you won't know it until you get it all the way back together. Just make sure they "seat" on the frame.
              • 37365
              High Voltage Power pack?
              • Counsel
                • Aug 2011
                • 530
                This guy has 3 threads about the same mpc2050 jaming, in one thread he completed the spring clutch replacement. I believe this has been solved already.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Counsel, that is indeed correct; I didn't quit know what i must do, so i did it this way...
                  And it seems i have now al the information that I can dream of!!!
                  Thank you all guy's, enjoy the weekend!
