Mp 3053 ceasing paper
  • CableGuy
    Impulse Drive Engineer
    • Oct 2008
    • 417
    Hi All
    I'm having an ongoing issue with a Mp3053 creasing paper in the fusing exit area. No jams, just a crease or two down the centre of the page. All the fusing rollers have been replaced and the entrance and exit guides cleaned of all hard toner or lumps of crap. This occurs A4 long edge, I can't say I've had it do it on the short edge. It seems to go well for a short period of time, or they aren't reporting it every time it happens. I'd be grateful if you've had this fault and could enlighten me. Thanks in advance
  • Counsel
    • Aug 2011
    • 529
    Re: Mp 3053 ceasing paper
    The fuser design on this is pretty much the same as the previous gen models like the 2550 and when they did that I would take the entrance guide off the bottom of the fuser and sand the two nubs in the center so they were completly flat like the rest of the guide and it always fixed the problem pretty much only happend on long edge feed or 14" length paper, or you can replace the guide with a new one.
