MPC3003 - Device Setting Information: Import Setting (Server)
  • ricmartinho
    • 142
    [Misc] MPC3003 - Device Setting Information: Import Setting (Server)
    Hi!
    Has anyone used this function on this model or similar? I have 20 machines on several sites and I want to import the settings without having to go locally to the machines. Device Manager NX Advanced Template doesn't work and shows this message on the logs: "Failed to suspend the SDK application on the device".
    Any help?
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: MPC3003 - Device Setting Information: Import Setting (Server)
    never used it, but I would contact my Ricoh SSS person about it................
    Mystic Crystal Revelations
      • 37529
      From what I remember from training it is primarily for installation. When you have multiple machines going to the same customer, you can setup onre machine and then clone it to the rest. Everything is copied over except those item that have to remain machine specific serial number, counters, birth certificate information and IP address.
      • ricmartinho
        • 142
        The answer from Ricoh was: "the feature shows on the machine's menu and on Web Image Monitor but it doesn't work".
        They say that only import/export settings to SD card works and I've done sucessfully but I need an alternative.
          • 37529
          If it shows on the WIM menu, that means that engineering had plans to implement it at some point in the future, possibly with the new 04 color models. You can always request a custom firmware but they may charge you to do it.
