Aficio MP 7500 display language
  • dradisic
    • Jun 2016
    • 11
    Hi all,
    Sorry for double thread,
    I needed firmware for Aficio MP 7500.
    I have a machine MP7500 which have the German language menu, I need to change the language to English but seems to have to change the firmware.
    Which are correct firmware, for printer, System Engine, LCDC and NIB.
    On my machine I have installed only German language and all the functions are in German, I do not understand, and so I need the English language menu.
    Is there any other way to change the language display menu from Deutsch to English.
    Attached I send you a document with the configuration list,
    Please if anyone can help me on this issue, unfortunately I do not have access to the ricoh portal to download needed files,
    Thank you in advance and best regards,
    Darko
    • 37738
    Re: Aficio MP 7500 display language
    Normally 2 languages are installed on an older machine, I have seen newer models with all languages installed. In User Tools it is the button below the "EXIT" that toggles the display language. If the language yo want is not available you will need the language firmware.
    • dradisic
      • Jun 2016
      • 11
      Thanks for replay,
      Yes, you are right, I have no choice for another language, only the German language.
      Could you please send me the English language firmware.
      See the screenshots in attachments.
      Best regards,
      Darko
      • Elmo
        • Feb 2010
        • 541
        Contact your Ricoh support site and request the Custom/Special firmware.
        or contact your local Ricoh Dealer and get them to request it for you
        I Used To Live To Fix Things Now i Fix Things To Live
        • vargue
          • Oct 2011
          • 404
          if yo want it contact with me plagio000@gmail.com
            • 37738
            Originally posted by dradisic
            Thanks for replay,
            Best regards,
            Darko
            There is no such thing as English Language firmware. The is only the Language Module firmware. When you load it, you have to select the 2 languages you want installed.
              • 37738
              Language is not a Custom/Special firmware.
              • dradisic
                • Jun 2016
                • 11
                Hello,
                I do not have the ability to contact my local dealer because is to much expensive, that's why I turn to you in this forum.
                Please if you can help me regarding this case and give me instructions on how to get the English language for my machine.
                Regards
                • dradisic
                  • Jun 2016
                  • 11
                  Hi everybody,
                  Can you someone help me how to update language file in my ricoh mp7500, with procedure step-by-step.
                  I have language file but I never do this action so please give me advice for this.
                  Thanks a lot in advance,
                  Regards
                  • CRISTIAN MULLER
                    • Feb 2013
                    • 145
                    Hi everybody,
                    Regards
                    make this kind of thing without knowledge is quite dangerous, you can find you with a bigger problem at the end.best mobe is to call your Local dealer.
