Ricoh Aficio 1045 SC542 Error Code
  • tcypy1961
    • 773
    I replaced the end thermistor on a Ricoh Aficio 1045 after noticing that the temperature was not rising above 70 degrees. After I replaced it I noticed that the temperature for the end thermistor was only registering at 102 degrees and wouldn't go any higher. I ended up cleaning the power source PCB connections after finding toner in that area. This didn't help with the temperature issue. I pulled both items to try in another copier. Any other suggestions for solving this problem? Thank you for any help given.
  • ccchuah
    • Mar 2009
    • 155
    Re: Ricoh Aficio 1045 SC542 Error Code
    Try to replace the centre thermistor and check the heater lamp also ..
    • bob marley
      • Jan 2012
      • 1339
      Had the same issue before ( think aficio 1035) and it was a defective BICU
      Live for yourself and you will live in vain. Live for others, and you will live again
        • 37422
        Check the thermostat at the front end of the fusing unit and the lamp connected to it.
        • Kosta25
          • Jun 2021
          • 10
          I have a defective fuser heater lamp on Ricoh 1035. How can i know the votlage (100v or 220v) and the power of the lamp?
            1) this thread is at least 5 years old.. we call them dead after 2 years
            2) it is a different model
            3) you never stated the error code
            4) how do you know the lamp is defective?
            5) what is the power in your house? 110v or 240v?
            6) start your own new thread stating: Model #... error code... what you have tried
            stop being a grave robber
              • 37422
              Hey grave robber, this thread is 3 years old, dead and buried. Start a new thread or be ignored. your choice.
                you were that last to comment on this before the robber and myself... that was in 2016 more than the three years you stated.
