PCL Command List for Ricoh Devices
  • PillePalle
    • 42
    Hi Guys
    I`m searching a PCL Command List for Ricoh Devices.
    Can someone Help?
    Kind Regards and Thanks
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: PCL Command List for Ricoh Devices
    As far as I'm aware the original Hewlett Packard PCL is now an Industry Standard (ISO).
    I could be mistaken, maybe Ricoh have branched out with a MFD language, like RPCS?
    You may like to view the following PCL link and you can update yourself with the required info.
    "https:\\en.wikipedia.org\wik\Printer_Command_Language"
    Click the below link for more printer protocols "http:\\www-01.ibm.com\support\docview.wss?uid=nas8N1019534"
    IBM Technical support search - United States
    HTH
    • PillePalle
      • 42
      Hi
      I searched around a little longer and i found this
      PCLLanguageSpecificationV3_080-1.pdf
      • dryhte
        • Oct 2023
        • 1
        Originally posted by PillePalle
        Hi
        [ATTACH]33265[/ATTACH]
        Thanks for this. I was able to find the printer type & from there derive the tray numbers (in my case: for Ricoh C3500 printer: see below)
        • Tray 1: \e&l8H
        • Tray 2: \e&l1H
        • Tray 3: \e&l4H
        • Tray 4: \e&l30H
