I am getting an error codeand I don't know if it has anything to do with it, but the image is crooked/ slanted.I am about to replace the development unit, but want to know if might be some kind of roller or something.You can't get at the TD sensor, you have to replace the whole development unit.MP C3503
SC362-01
Tags: None
Re: SC362-01
all i can find is whats in the service manual, nothing in Goose's Guide.
TD sensor output: Vt (SP3-210-001 - 004) < output lower limiterror threshold (SP3-211-004) is continuously below the lowerlimit occurrence threshold value (SP3-211-005)TD sensor connector missing/dropout1. TD sensor connector missing check2. Check whether there is any error in the TD sensor harness(disconnection, etc.)3. If the sensor is defective, replace the development unit.
k developer unit. -
Re: SC362-01
k developer unit.Comment
