mpc5503 df3090 jam 16
  • ash_572
    • Oct 2008
    • 523
    [Jamming] mpc5503 df3090 jam 16
    adf on a mpc5503 is giving a jam code of 16 registration. paper stops at the skew sensor but does not drive to the reg sensor.
    all sensors are working fine in input mode.
    adf feed belt and sep roller have been changed.
    sometimes it will work fine
    any ideas??
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: mpc5503 df3090 jam 16
    I know this seems simple, but have you tried blasting the paper path out with canned air?
      • 37490
      Check the transport motor and associated drive train. Also check the paper buckle.
      • ash_572
        • Oct 2008
        • 523
        Yep
        • Lanierman
          • Jun 2015
          • 9
          Please clean the registration sensors
          • Besserwisser
            • 25
            any ideas??
            I think there is a new firmware for the adf to prevent jam 014 and 016... 1:290:03
            Symptom corrected:
            • JAM01 or JAM16 may occur when scanning thin originals.
            • JAM14 may occur as a result of an unwanted delay in feeding out the last sheet of the original.
            • Lifting up the ADF during initialization may cause JAM14 in the process following the initialization.
