Scan to Folder Problem after MS Update
  • PillePalle
    • 42
    #16
    Re: Scan to Folder Problem after MS Update
    Originally posted by KenB
    There is a KB article on Nuance's site about this.
    can you drop me over the Link. Because i also got to take care of some major Clients that work with Equitrac. So just in case one them pops up with this issue i`m prepared.
    I thank you in advance
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      #17
      Here it is:
      • PillePalle
        • 42
        #18
        Hi Guys
        Got another Document i made where all the Informations are inside. The Key that has to be changed as well as the Domain Name Issue
        Scan 2 Folder funktioniert nicht nach MS Update v.1.0.pdf
        Don`t get confused by the Title i simply forgot to change the Title to English. Anything inside in English.
        • rthonpm
          • Aug 2007
          • 2859
          #19
          Originally posted by Brianneoe
          Hi All,
          Workaround
          To avoid this issue, please conduct the following workaround:
          - Change the priority port for the SMB client to TCP 445 (Direct Hosting/CIFS) by using telnet.
          Change the priority port procedure of the SMB client:
          1) Connect to the target device by using telnet from the command prompt and log in as the administrator.
          2) Enter the following command:
          >smb client port 445
          RICOH Maintenance Shell.
          User access verification.
          login: ***** (enter the Administrator login name)
          Password: (enter the password)
          User access verification ... OK.
          RICOH ********
          Network Control Service Ver. 12.78
          Copyright (C) 1994-2016 Ricoh Co.,Ltd. All rights reserved.
          msh>smb client port 445
          msh> smb
          Workgroup Name : WORKGROUP
          Computer Name :
          Comment :
          Notification : Off
          Protocol : IPv4
          Client Port : 445
          Client Auth Level : 0
          Client WSD Browse : Off
          Client Write Mode : Async
          msh> logout
          Logout Maintenance Shell.
          Do you save configuration data? (yes/no/return) > yes
          Yes.
          Now, Save data.
          Or
          Long-term this really is the solution for this issue. WINS has been a dying protocol ever since DNS came on the scene, and Microsoft has even deprecated the feature in Server 2012, while it's still available there's no guarantee as to how long it will be supported.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            #20
            OK, here's a new wrinkle...
            The telnet session displays IP v4. What if the customer is running IP v6?
            Or is that a non-issue?
            I just had that question come up today.
            • rthonpm
              • Aug 2007
              • 2859
              #21
              The setting is global, you'll just have a longer IP to enter to connect.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                #22
                I just read that IP v6 does not work with Port 139 for SMB.
                Which makes sense, as earlier today we ran the command "net stat -a" ( no space between net and stat...blame my iPad for that), on the 2012 Server, and it did not show Port 139 at all, but a bunch of connections on Port 445.
                Thanks, though. We will try telneting to the IP v6 address.
