SP-C242sf SC-819
  • ABS tect
    • Sep 2013
    • 511
    SP-C242sf SC-819
    I have sporadically been getting these SC-819 codes on this machine, I have the service manual and know what it says about the controller board being defective and all but to fix these i have either just been powering off/on the machine, or going into engine maintenance and executing "init engine eeprom", and afterwords doing an ACC. Does anyone know why i might be getting these codes and the best way to handle them? I don't feel like powering off and on the machine is a permanent fix nor do i think that executing the eeprom is quite what it needs. Any suggestions are much appreciated, thanks!
  • LNorris
    • Sep 2008
    • 645
    Re: SP-C242sf SC-819
    have you updated firmware?
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      +1 FOR THE FIRMWARE.
      • ABS tect
        • Sep 2013
        • 511
        No I guess i haven't been doing any firmware updates on these guys
        Alright thanks so much for the input, I will do these from now on! Thanks!
        • sturmtrooper
          Copier Combobulator
          • May 2016
          • 587
          I did an engine eeprom clear on one of those and it trashed the total counter on it. When I get some time I'm going to update the firmware and see if that fixes it.
          • ABS tect
            • Sep 2013
            • 511
            Also I learned when you do an EEPROM clear it throws the color regisration out of whack...so make sure you perform a color registration on it afterwords.
