Error SC300
  • jimmycabral
    • Jun 2016
    • 35
    Error SC300
    Anyone can provide me the other reason for this error. I cleaned the corona wire and the grid but still showing after couple of copy.
    regards
    jc
  • tjvincent
    • 280
    Re: Error SC300
    Model # ?
    • jimmycabral
      • Jun 2016
      • 35
      Re: Error SC300 for ricoh Pro 1106Ex
      Ricoh Pro1106Ex
      • tjvincent
        • 280
        Re: Error SC300
        I would start by replacing the wire and grid and see if that fixes it, if not it may need the whole corona assy, you may also want to make sure you don't have some toner blowing out from the dev unit or toner supply area causing that code.
        • techmann
          • May 2016
          • 41
          Re: Error SC300
          Try replacing the whole corona, make sure you clean the ID sensor also.
          • Counsel
            • Aug 2011
            • 529
            Re: Error SC300
            The other thing to check is on the corona assembly make sure the two springs at the back are sicking out 1/4 inch or more, i have had some slink there way up to the corona unit and not get a good connection to the rear of the machine and cause this code as well, you want good contact between the assembly springs and the block screws in the back of the machine. Anywhere from 180k to pm they tend to fail though and just need to replace the wire and grid.
              • 37399
              • jimmycabral
                • Jun 2016
                • 35
                Re: Error SC300
                Thank you guys, I just waiting the part i ordered for the corona and grid then if don't work I will move through the input you mentioned here.
                cheers
                JC
