Hi, i have checked thermal fuse, heat lamp and cleaned thermistor of build up. I went in to programming to reset sc546 ,turned off print to confirm, turn unit back on then display reads "reset fusing unit correctly. ive had it in and out correctly the best i know? what have i done wrong? i just wanted to reset to see if thermistor would act up or whether a power supply is in order. I know hytec repairs them. thanks in advance
lanier laser lp135n code sc 546
