TWAIN SCANNING
  • fritzyas
    • Jul 2011
    • 73
    TWAIN SCANNING
    will network twain scanning works if pc and scanner are in different subnets? Thank you for support.
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: TWAIN SCANNING
    Never played with TWAIN drivers on Ethernet that much, mainly on USB.
    Something to try:
    1. Enter a fixed IP or host name in the app setting if using on a different subnet.
    2. Make sure the twain application has access both directions through the firewall for PUSH-PULL scanning.
    3. Check that port 443 : Web HTTPS is open for html web browser interface.
    HTH
      • 37474
      Re: TWAIN SCANNING
      If you are talking about different subnets of a corporate network, it should work as long as subnet masks and router (gateway) are correct. If you can ping from both ends then it should work.
