from Japan About SP-5-816-001 of SP mode MPC2802
  • osamu takahashi
    • 7
    機械翻訳です
    こんにちはみんなしかし、それは初期値をonにすることではなく、電源offを返します0に設定した初期値 2からsp-5-816-001についてです。または他の設定が関連していますか?
    • 37483
    Re: from Japan About SP-5-816-001 of SP mode MPC2802
    It is a machine translation
    Hi guys, however, it is not to the initial value to on, but from the initial value 2 is set to 0, which returns the power off for sp-5-816-001. Or other settings are relevant?
    SP 5816-001 is set according to the Remote Service product is being used. Set at 2 allows the RCGate to find the device when embedded @Remote cannot be used due to the number of devices or presence of devices without embedded @Remote capability.
    SP5816-001が使用されているリモートサービス、製品に応じて設定されています。 @Remoteが原因でデバイスまたは組み込み@Remoteの機能を持たないデバイスの存在の数に使用す ることはできません埋め込まれたときに、デバイスを見つけるためRCGateは2で可能に設定 します。
    • osamu takahashi
      • 7
      Translation was Japanese!
      I didn't notice until it was pointed out.
      I'm sorry!
      Mr. slimslob Thank you very much for your answer. When @REMOTE is set, is it OK for SP 5-5816-001 in the state of 2 of defaults? @ RIMOTE was cleared, so does remote service break?
      • osamu takahashi
        • 7
        I'm sorry!
        Remote service of SP-5-816-001 is set as 0 from 2 of defaults, a power supply, off and On, when, I return to 2 of defaults again. Is it somewhat well-founded?
