No "Print Volume Use Limitation" on Ricoh 5000
  • kazihaha
    • 100
    [Misc] No "Print Volume Use Limitation" on Ricoh 5000
    Hi Everone,
    I'm using Ricoh 5000, but no menu "Print Volume Use Limitation" in Admin, I also used firmware 5001 for this 5000 but still no "Print Volume Use Limitation".
    Please help me.
    https://sieuthithietbivanphong.com
    • 37557
    Re: No "Print Volume Use Limitation" on Ricoh 5000
    "Print Volume Limitation" is not supported on the Ricoh 4000/5000. If you want to limit the number of pages that each users can make, you will have to use the User Account Limits Application. User Account Limits Application requires JAVA VM be installed. If you are in the US, you can find it on the Solutions portion of TSRC under security.
    • kazihaha
      • 100
      Hi, when I access through web, it said 5001.
      I'm in VietNam, how can I find the link to download the software?
        • 37557
        You have to go through your Ricoh support site. First make sure that the 5000 has JAVA installed.
        • kazihaha
          • 100
          It's a Java Extension Card. I need to order from the Ricoh ^^
          I'll find a Ricoh 5001 to use that function.
          • darknet93
            • Nov 2015
            • 89
            Hi.. how about if MP C3502/3002 & MP C3001/3501 ?
            i cannot find the "print volume use limitation unit count setting" at the machine. (refer image)
            i have done all step but when come to this step i din't found this function
              • 37557
              [ATTACH=CONFIG]33692[/ATTACH]
              Unit Counting is for weighting job types. For most normal usage, leave everything set at 1. The way every sheet of paper will be counted the same as the meter count, i.e. most pages will count as 1 and 11X17 will be counted according to the settings in SP.
              • darknet93
                • Nov 2015
                • 89
                sory but i din't understand what u said. do i need to turn on the function inside service mode ?
                because right now my machine din't show the "print volume use limitation unit count setting" inside administrator tools
                or if you don't mind can you teach me step by step on how to do the limit pages colour setting for MPC3001/3501 or MPC3002/3502 ?
                • kazihaha
                  • 100
                  Hi I worked with the 5001 yesterday, but does not see that function. Do you know which model support Print Volume Use Limitation
                  • kanagavel
                    Service Engineer
                    • Feb 2020
                    • 78
                    Hi friend, in Mpc3002, if you use user code authentication you can set print volume limit
                    • davel
                      • Oct 2011
                      • 1107
                      Only about 8 years too late.
