MP4001 & Windows Server 2012 r2
  • Leebs14
    • Feb 2014
    • 457
    [Error Code] MP4001 & Windows Server 2012 r2
    My customer has upgraded to Windows server 2012 r2 and the SMB scanning now doesn't work.
    Updated firmware from Ricoh tech site but it still doesn't work.
    Is it supported or not?
  • sparks45
    • Jun 2014
    • 25
    Re: MP4001 & Windows Server 2012 r2
    Yeah was released Feb 2013
    • Leebs14
      • Feb 2014
      • 457
      Have I missed something then? What was released?
      • mikedci
        • Jul 2010
        • 227
        Deja Vous
        Should be supported. In the US system needs to be 1.03 or higher and Network needs to be 7.38 or higher...not sure if the UK is different...
        • sparks45
          • Jun 2014
          • 25
          Network Support 7.38 and System Copy 1.03 is needed. both on my-ricoh
          • Ottawatech
            • Feb 2015
            • 63
            Could be this:
            Update KB3165191
            After you install this security update, the following changes are applied: NETBIOS communication outside of the local subnet is hardened. Therefore, by default, some features that depend on NETBIOS (such as SMB over NETBIOS) will not work outside the local subnet.
            Have your customer's IT look into the KnowledgeBase article quoted above, it'll tell them what to do.
            Tim
            Nothing works quite so well that I can't totally disable it by trying to make it a little better.
              • 37495
              Originally posted by Ottawatech
              Could be this:
              Update KB3165191
              Tim
              If the customer has a domain, the entire domain is considered as the local subnet. You have to make sure that the domain name is correct in the interface settings. Also, there must be a valid SMB computer set in the interface settings and the first DNS must be the domain DNS. This will ensure netbios name resolution. Using the IP address of the server is no longer supported.
              • richardjj
                Technician - I.T Support
                • Feb 2010
                • 18
                Number: RIB0215
                Created on:
                11 July 2016
                Product:
                All products capable of native scan to folder
                Subject:
                Scan to Folder not working after Windows updates
                Issue:
                Scan to folder may fail if a Windows Update that was released on June 14, 2016 has been applied to the Windows desktop or server operating system.
                The Windows update may include KB3161949, which causes the issue because it restricts network connection using TCP port 139 (NetBIOS over TCP/IP). As a result of the restriction scan to folder using TCP port 139 across a subnet may be denied.
                Windows 10 may have KB3163017 or KB3163018 applied, which has the same affect.
                Effected OS:
                Windows Vista, 7, 8 and 8.1 (KB3161949).
                Windows Server 2008, Server 2008 R2, Server 2012 and Server 2012 R2 (both 32 bit and 64 bit, where applicable). (KB3161949).
                Windows 10 (both 32 bit and 64 bit (KB3163017 or KB3163018).
                Action:
                GW, GWNX and KIBO Controllers
                1. Make sure the firmware is up to date.
                2. Change the priority port for the SMB client to TCP 445 (Direct Hosting/CIFS) by using telnet as follows:
                a. Open a command prompt and connect to the MFP using telnet by typing the following:
                telnet <ip address of mfp>
                Note:
                If you get see a message that telnet is not recognised as an internal or external command go to Control Panel > Program features > Add or remove Windows components and install telnet client.
                Once logged in you will see the following:
                RICOH Maintenance Shell.
                User access verification.
                login: ***** (enter the Administrator login name) Password: (enter the password) User access verification ... OK. RICOH ******** Network Control Service Ver. 12.78 Copyright (C) 1994-2016 Ricoh Co.,Ltd. All rights reserved.
                b. Type the following command to change the smb port to 445:
                smb client port 445
