Re: mpc2800 sc543 overheat
You either replace the fusing unit, or risk changing enough parts that end up costing more than the fusing unit did. Not to mention the time taken to resolve the fault.
I have had success replacing the connector block and harness on a 3000 with SC553/543, maybe the same for you.
