af 3045
  • Gab
    • Aug 2015
    • 671
    af 3045
    MACHINE has made 245k copies . I changed drum at 120k. Now image is light (not too light) . If i change only drum qill it be ok or do i have to replace developer too.
  • totoro
    • 568
    Re: af 3045
    Since the developer is only rated at 300k , I would probably change it now. I always did drum , cleaning blade, charge roller, and developer at the same time . It seemed to work better that way. Make sure that your optics are clean also.
    Totoro
    • Polarbear
      • Feb 2012
      • 1070
      Re: af 3045
      +1
      Rule of thumb is if the image is solid, but there is background - drum is toast. iF the image is light, dev is due for replacement.
      Press the GREEN button!!
        • 37532
        Re: af 3045
        Originally posted by Polarbear
        +1
        Not necessarily so with Ricoh 35, 40, 45 and 50 Page models. Regardless of the condition of the drum, if the development roller is coated with toner, it can go from light print to background and back to light print in the matter of hours. Only solution is to clean or replace the development roller, clean all toner residue from the PCU and replace the developer.
        • banginbishop
          grumpy old git
          • Oct 2007
          • 894
          Re: af 3045
          Also what's vsg vsp etc saying?
          Incontinentia Buttocks
          • tufbnme
            • 493
            Re: af 3045
            Also, use only OEM drums, aftermarket ones suck, especially in that platform.
            • bob marley
              • Jan 2012
              • 1339
              Re: af 3045
              after performing the ID sensor initial setting ( 3001 2 )
              Live for yourself and you will live in vain. Live for others, and you will live again
