Check counter
  • aalex_bom
    • Jan 2008
    • 214
    Check counter
    How are you check or/ and printing counter list for small size paper?
    For example: 8,5"x5,5" , Ricoh Mpc6501
    help me, please!
    • 37047
    Re: Check counter
    In the 8000 portion of the SP data mode printout.
    • NeoMatrix
      Senior Tech.
      • 3514
      Re: Check counter
      Try setting SP 4303-001 = 1 to detect "A5" paper size.
      HTH
      • aalex_bom
        • Jan 2008
        • 214
        Re: Check counter
        HTH
        I'd check the total counter output, not original paper
        #slimslob
        i think SP 8581, do you think?
          • 37047
          Re: Check counter
          #slimslob
          SP 8581 is just the various total counters broken down by type of operation but not paper size. If the paper is the only size fed from a specific paper tray, then you can use SP 8451 which gives you the total paged from each paper tray.
          • aalex_bom
            • Jan 2008
            • 214
            Re: Check counter
            Thanks you for your help!
