Ricoh MP 171 SPF need Files from SD Card (Slot 1)
  • pingpong
    • Aug 2016
    • 32
    Hi Experts,
    unfortunately the files on the SD Card in Slot 1 (COM2_ALLPL?) are lost.
    Who can send me the fieles or a download location?
    Many thanks!
    Best regards
    Michael
  • fshead
    • 2356
    Re: Ricoh MP 171 SPF need Files from SD Card (Slot 1)
    Originally posted by pingpong
    Hi Experts,
    Many thanks!
    Best regards
    Michael
    if it was that easy but i doubt it is.
    you will have to find a new or used card
    • pingpong
      • Aug 2016
      • 32
      Thanks. I will get an used card ...
      • fshead
        • 2356
        NOT SURE WTH THAT MODEL BUT IF PS3 postscript is on it you might have to remove zoffy files for it to work on a used card..
        on the small colors mpc2050 i installed used ps3 cards and that did the trick
        • pingpong
          • Aug 2016
          • 32
          I use an MP 171 SPF and I formatted accidently the Original SD Card ... without the PS3
          • fshead
            • 2356
            then you should be ok..
            i have done that wth an older color printer copier and could not make it work..
            • pingpong
              • Aug 2016
              • 32
              Hi fshead,
              thanks for your help. I'm very happy, I found an SD-Card image on my Fileserver. I copied the files to the SD-Card and it works!
              Fortunately, all failed firmware updates like Scanner, Printer ... (see my other Thread) are worked! The stupid write protection
              switch was take me busy some days ago.
              Best regards from germany
              Michael
              • fscialla
                • Oct 2020
                • 1
                Hi,
                do you have a copy of file in PostScript sd card?
                • fshead
                  • 2356
                  Originally posted by fscialla
                  Hi,
                  4 year old tread
                  start a new one
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Hi,
                    Old thread also you can't copy postscript cards
                    Regards Mark
