Ricoh Fax MPC4501
  • DBT
    • Jul 2011
    • 24
    Ricoh Fax MPC4501
    Hello-
    Does anyone no how to change the "tx file status" to show up the sent fax numbers instead of a name. The display seems to show what the receivers name is set to for example some will say FAX SERVER. I would like it just to display the number it was sent to. hopefully just a parameter needs to be changed. Thanks
    • 37494
    Re: Ricoh Fax MPC4501
    It is a parameter on the machine that you are sending to.
    • Gary Bowen
      Bowdog
      • Mar 2008
      • 250
      If I understand your question you what to see the telephone number listed on the Fax TX Status Report? In FAX SP Mode: SP 1-101-010 (System Switch 9) set Bit 7 to "1" to show FAX number dialed on reports.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Just as an FYI...
        When end the name of the other party shows as "Fax Server", that means it is just that, a fax server, and not a standalone fax or MFP.
        I work with Rightfax a lot, and I am almost positive that is the default name.
        That default really should be changed to something more meaningful, such as "ABC Company", but that doesn't always happen.
        • DBT
          • Jul 2011
          • 24
          Gary, I looked that up that System Switch 09 bit 7 in the manual and that looks like my answer. I will be trying that out on Monday. Thanks for all the replies.
