silly question i'm sure...MP6002
  • LNorris
    • Sep 2008
    • 645
    we just received one, i cant find any handles to lift on it to get it off the pallet. i'm not trained on this one.
    am i missing something? dont want to yank my back out moving it
    thanks
  • tufbnme
    • 493
    Re: silly question i'm sure...MP6002
    The pallet is made of flash wood, light it on one corner and the pallet will burn away very quickly leaving the machine sitting on it's castors. Its in the manual.
    Seriously?
    • LNorris
      • Sep 2008
      • 645
      sorry mpC6502.....u wanna move it for me then?
        • 37494
        You are going to have to manhandle it off the pallet. There are layered cardboard supports under the machine that keep it from rolling. Usually takes a coupe of techs to lean it to one side as you remove the bottom supports.
        • LNorris
          • Sep 2008
          • 645
          thats what i was afraid of...all of us are falling apart physically. at least i know im on the right path.
          • NeoMatrix
            Senior Tech.
            • 3513
            You need one of these with two lifting straps around the handles of the copier....
            The boom extends out over the wheels...
            The whole device folds away when not in use.
              • 37494
              MP C6502 doesn't have handles. You would have to work the straps under the machine.
              • NeoMatrix
                Senior Tech.
                • 3513
                ---Update image-----
                The lift-grip "U-shape" handles go into the lift position of the copier.
                You will also need a "I -shape" spreader bar that goes above the copier when lifting.
                • Polarbear
                  • Feb 2012
                  • 1070
                  This is where Ricoh can take lessons from HP.
                  All their large machines come with carboard (use once) ramps that helps one not having to lift the machine, but roll it off the palette.
                  Press the GREEN button!!
                  • DRichard
                    • May 2008
                    • 482
                    thanks
                    We have a forklift in our warehouse. It works perfectly. No damage to equipment or employees. It is also perfect for stacking/unstacking inventory shipped in on pallets.
                    "Enjoy every sandwich."
                    -- Warren Zevon
                    • dpoutz
                      • May 2011
                      • 78
                      thanks
                      We use a tow motor to take it off the pallet
