cypher sc 995 mpc 3000
  • pLatik
    • 169
    hello to everyone,
    i want to know if anyone have the method of cypher to reset the I/O (FUSE
  • pLatik
    • 169
    Re: cypher sc 995 mpc 3000
    yes, i know, but if you read this post: http://www.copytechnet.com/forums/ri...-sc-995-a.html
    you can view that the member chyper found a method to this
    • skynetto
      • Sep 2012
      • 257
      Replace the fuser. It has blown even if you dont see nothing damaged. It gives continuity on board but infinite off board.
      • Herostrat
        • Oct 2012
        • 220
        I'm not shure if those boards are the same.if board numbers don't match then don't go with it but if they do then u have mismatched Serial numbers of machines,happens often when using boards from used machine to test and detect malfunction.
        SP5811 is to change serial number but be carefull cause it's easy to mix them up and then have 2 machines with sc 995.
        Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
        • pLatik
          • 169
          Thanks, for the reply. i see the fuse and the values of it in the board, but i was in doubt and decided to ask on forum. i will buy a fuse and test the results.
