SC 187 error code
  • redlego
    • Jul 2025
    [Electrical] SC 187 error code
    hello, can anyone help with this error code machine shows doc feed jam twice then sc 187. i have tried changing sensors
  • Gary Bowen
    Bowdog
    • Mar 2008
    • 250
    Re: SC 187 error code
    What machine? What sensors?
    • redlego
      Mp 9002 sensors for lift table.and adf closed sensors
      • Gary Bowen
        Bowdog
        • Mar 2008
        • 250
        SC 187 is CIS Black Level Error (Black Level scanned by CIS is abnormal). First thing I would do is give the Cover Plate on the CIS (Contact Image Sensor) and the White Roller a very good cleaning - make sure it isn't getting a false read because it's dirty. In case you wonder where this is, it's in the exit path on the underside of the Feeder (your side 2 for copying). Nothing to do with ADF Closed Sensor or Lift Table Sensor.
          • 37483
          SC 187 has nothing to do with those sensors. SC 187 has to do with the CIS, Contact Image Sensor, that reads the back side of originals. Check the connectors mentioned in the service manual. If you do not have a service manual and/or training on this model, you should not be working on it.
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            I had a 6001 do the same thing. Change the EEPROM on the BCU board and it went away. Worth a shot as it's a cheap part. As others have said cleaning the CIS and checking all the connections going to it is also a good idea.
