Ricoh MP9000
  • antoney suresh das
    • May 2011
    • 103
    Ricoh MP9000
    Hi Guys I've a question I work on both Xerox5790 and Ricoh MP9000 there is a feature on Xerox which is job build where one sided and duplex copies with various paper sizes and orientation can be run in one single job does MP 9000 have the same feature or is there anyway of creating a print file where one sided copies can be printed as single side and back to back as back to back.
    Sent from my Lenovo K920 using Tapatalk
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh MP9000
    There is a mixed size mode for copying, it might also be on scanning too but cannot find it in the manuals.
    See: B2357600.pdf
    If the Mixed Sizes button is missing see Copy/Document Server Reference: Aficio MP 9000/1100/1350 download page
      • May 2011
      • 103
      Re: Ricoh MP9000
      Hi Ruben Thanks for the post but the first pdf file is not uploaded it's throwing up an error on download can you please post it again.See: B2357600 pdf
      thanks again
        • 37558
        Re: Ricoh MP9000
        Look for a button that says "Batch"
          • May 2011
          • 103
          Re: Ricoh MP9000
          😃"Batch " doesn't allow you to toggle between single sided and two sided like in Xerox
            • May 2011
            • 103
            Re: Ricoh MP9000
            With a lot of juggling I finally found the way to mimic the Xerox job build feature thanks guys
