toner blockage in Toner Collection Coil
  • aaahmmm
    • Aug 2009
    • 103
    i have a problem in 2 machines mp7001 and 9001 the problem that the toner blocked in the PCU at the end of the Toner Collection Coil to the Toner Recycling Ass'y ,this blockage damage all the pcu gears and coil , i change them all for both machines but the problem still , the Toner Recycling Ass'y is working and the coil is rotating also i change it with gear but no help .
    Please advice
  • vargue
    • Oct 2011
    • 404
    Re: toner blockage in Toner Collection Coil
    Did yo use the same toner in both machine change toner .... toner is bad
    • TonerMunkeh
      Professional Moron
      • 3865
      When's the last time the toner sep case was changed?
      Hit it.
      • aaahmmm
        • Aug 2009
        • 103
        not from long time ,also i use another toneIMG-20160909-WA0007.jpgIMG-20160909-WA0008.jpgIMG-20160909-WA0009.jpgr lot but the same , the problem that the toner did not reach to the top of the Toner Recycling Ass'y , pleas see photos
          • 37544
          Check the collection coil in the pcu. If it is damaged, the waste toner never gets to the recycling unit. If this is allowed to go on too long, the opening in the pcu will become clogged with toner and you might have to replace the entire pcu.
          • fshead
            • 2376
            Excessive heat can cause toner to build up too and i usually pull the front coil and vacunm .
            and then pull drum unit remove the sensor and vacunm everything in the cleaning unit
            • Iowatech
              Not a service manager
              • 3930
              On a closer examination of the second picture you shared recently, it appears that there is a broken tooth on the left hand side of the gear. It doesn't appear that badly broken, but it does indicate that the auger inside that unit has seized up and may have broken internally. That really doesn't make sense as you said the unit was turning.
              It might be something to check if time permits though.
              If I am wrong, I apologize for wasting your time.
                • 37544
                After Iowatech's post, I took a closer look at the pictures and the first one obviously shows blockage of the opening coming out of the PCU. I also do not see the end of the collection coil and it looks like someone has made an attempt clear the blockage and broken a chunk off the side of the plastic protrusion that mates with the recycle coil.
                • sturmtrooper
                  Copier Combobulator
                  • May 2016
                  • 587
                  I had a machine do this for exactly this reason.
