AF2022 J001 copying only
  • leogets
    • Jul 2012
    • 5
    [Jamming] AF2022 J001 copying only
    hi all ,
    basically i have this sales lead of a machine with a strange jamming problem.
    it will only jam on copying. data prints fine ,logging ect
    paper gets to the same position every time no matter what tray is used, just leaving the feed station
    jam code 001 power on jam
    no other jams or errors logged
    any ideas
    thanks
    lee
  • rthonpm
    • Aug 2007
    • 2859
    Re: AF2022 J001 copying only
    Are you sure that prints are defaulting to Tray One? I've had a few machines where the printer and fax have been defaulted to use a different tray. It made troubleshooting tray issues extra fun since I'd look for a problem I couldn't duplicate in every function.
    • leogets
      • Jul 2012
      • 5
      yes mate i first proved that all trays were jamming in the same manor then done all other tests from tray one only
        • 37550
        J001 during copying will occur when the machine thinks that a door has been opened and closed. This is usually occur when a door switch is going flaky. It probably occurs only in copying because during printing you normally do not have an operator leaning on the machine and introducing extra vibration.
        • ABS tect
          • Sep 2013
          • 511
          Maybe check registration? If there isn't enough white border for it to grab on to and the color comes all the way to the edge of the paper that could be causing it to jam...just a thought. And it could be fine when printing because those are two separate registrations.
          • copyaction
            • Oct 2007
            • 991
            Size wheel on the drawer on the wrong size.
            otherwise it is most likely giving a non feed jam due to al the normal reasons
            feed tire bad, lift spring broken, end fence too tight, lift gear cracked
              • 37550
              Neither of these would cause a J001 - Jam found at power on.
              • Mark Bbb
                • Jun 2012
                • 1662
                Due to the pressure on the op.panel while pressing the start key, it might be that something get's blocked.
                Did this problem happens after a PM?
                • gear13z
                  • Sep 2011
                  • 68
                  do you try to change the interchange unit?
                  .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
