Ricoh GX 3050SFN display saying *Warning Remove Paper*, and then Ppr Misfd: Scan.Unit
  • patterson70
    • May 2010
    • 603
    This is my personal machine I have been using for years and then this came up. I can find no paper inside anywhere. I have replaced from another working same machine: the doc feeder, scanner unit, the main board under the scanner unit. And also the waste container just in case that was messing things up. But the problem persists. Any ideas what this could be? I know, this machine does not have a lot of fans, but it has worked for me pretty well and I have a lot of gel inks still in stock.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh GX 3050SFN display saying *Warning Remove Paper*, and then Ppr Misfd: Scan.
    Is it jam 14? If so, the encoder that runs through the print head is dirty. Clean both encoders.
    Hit it.
    • patterson70
      • May 2010
      • 603
      Hey it didn't say Jam 14 anywhere but I cleaned it and voila, working now! Many thanks!
      • TonerMunkeh
        Professional Moron
        • 3865
        No worries. Bit of periodic maintenance is required if the encoders are dirty, take the maintenance unit out and run it under a tap to get rid of the excess ink, get a wet cloth and wipe the print heads once. They run a little happier after that.
        Hit it.
